Discuss Whats the worst shock ( Electrical ) you have received and how ? in the UK Electrical Forum area at ElectriciansForums.net
During the war ...................... no start again.
Back in the winter of discontent ( Sorry Mr Shakespeare/Bacon) and the 3 day week, we had the task of installing a standy Gen set. Well we had done all the donkey work and we were doing last connections back from the ATS to the main Bus.
It was decided to save time on isolating everything and then go round resetting and checking everything, it would be done live ........after all we are talking pub time here.
I was a 2 yr apprentice by then and the guy that was going to do the "live" connection went off to get some lugs and crimpers and I was tasked to keeping out of the road. Well I decided to speed things along a little and prepare the way. There were 2 holes predrilled in the Red White phase bus and I decided I would fit the 5/8 bolts and nuts into the holes for him, so he could then just slide the lugs on an tighten with the nut,U washer and spring
All was going swimmingly, mat down and mat across the red phase and done the red. Started on the White phase and as i put my hand through between the bars the spanner I was holding, yes typical apprentice, bridge the phases.
Next thing I knew was darkness, and someone shaking me, as I laid against the wall a good 6-8 foot from the bus ..... my left arm was numb, my head was cut open and my heart was doing all sorts, I looked into a torch of the sparks and after a vitriol of abuse................it ended with and that's a new spanner you owe me.
Still today I don't exactly know what was on that bus, and I still get pins and needles in my left arm if I do too much impact work as I obviously damaged something ......I'm just glad I can still write this, not because of the belt, but I survived the sparks.
im lucky that i have only ever recieved minor belts at the start of my career.
Ive nearly had an accident on a large panel (1MVA), where i opened a section to find that the sheilding had been removed from the busbars. I was tesing Ze & phase rotation. The bloke i was working with came in from outside and dropped his hardhat onto a table, making me jump, as i was placing a croc clip onto a bolt on the bsubar. I gave him a -------ing (hes twice my size), and now if im doing testing of any sort, he is now as quiet as a mouse, as he knows how dangerous it is.
Dont know about the worst but the daftest one....when i worked in a small electrical engineers, we used to build one off panels of various sorts and one day i was just checking through one that had been completed, we used to make sure all contacters/relays worked as should do. i could not find the probe for the multmeter so just stuck a lead with a crocodile clip on a screwdriver and used that to check voltages in varios points. (I know, i did say it was the daftest!!)
Going fine until after looking at the drawing checking something out, picked the screwdriver up and with one finger touching the bare blade of it stuck it straight into a live terminal. Hell of a crack cos other hand was resting on metal caseing.
Didn't dare own up to it to other lads. what made it worse was i did it again two minutes later ! :)
550V dc from one of my amps, the bleeding resistor was open circuit so capacitor didn't discharge. Fell of my chair, I did. From that day on I enjoyed 240V ac :icon11:
In two minds with this one got a cracker of a belt from a faceplate starter (showing my age i know) but also had a beaut from a set of slip rings....which was entirely down to my own stupidity!
I've only had one electric shock when I was a 10 year old kid, I picked up a separated coupler to re-couple it, unfortunately for me TV installer who had wired it up had put the plug on the supply side and I got zapped when I grabbed hold of it.
Once picked up a commercial microwave that was faulty so i could get to the plug, and got a real zap, the most awake ive been in years, i never had to pay for my m and s staff breakfast again though
I have had a 500v DC belt a few months ago - launched me 6 foot away - had to sit down for a few mins after that one.
This was done because I was an idiot and did not isolate the machine as I could not be bothered to wait the 5 minutes for a UV lamp to cool down before isolating the machinery.
I accidentally touched the wrong bit I find that the more careful I am the more mistakes I make!
ive had a 5000v belt,hardly felt it...it was one of those horse electric fence things tho,gives a strange belt,like you have to touch it again for fun...
:24:
I worked in a very old animal feed mill, just after finishing my apprenticeship, which was a mass of conduit cables in galv trunking all over the place. Needed to trace a supply one day, so after locating the correct 3 phase cables I decided that it would be a good idea to run my hand along them to see where they left the trunking. What I didn't realise until after the event, was that mice had been living in there and had removed the insulation from a section of cables (and yes, I found a few little skellies in there when replacing the cable later). 415v across the hand was not pleasant.
That's what really scares me about these short training courses...even after 4 years I was still making stupid mistakes, yet these guys only have a few weeks in a classroom before doing it "for real".
Just 17 days now, so you can be ''really really scared'' now!!! lol!!
Reply to Whats the worst shock ( Electrical ) you have received and how ? in the UK Electrical Forum area at ElectriciansForums.net
  • Locked
https://uk.yahoo.com/news/boy-10-dies-receiving-electric-093000771.html I must say in my 25 years on the job , hotel / hostel / b & b wiring is...
I am installing some driveway lights. The customer wants to be able to switch them on from t he house, but also have a PIR at the driveway...
I experienced an electrical shock while replacing an A/C Fan Coil's 120vac, single phase motor that was above the ceiling grid in an office, while...
4K
Hi all. Sort of an interesting one. I had a call from a client to say she is getting a shock when using the shower. I told her not to use it and...
Hi all, I've recently had an oven installed by AO and afterwards I noticed in the installation instructions that the electrical connection needed...
