Discuss Why, just why !! in the UK Electrical Forum area at ElectriciansForums.net
NDG Elecs
Metal enclosure, plastic front cover, mismatched RCDs that push them out of line.. could get a new board for £70 ish, but no, got this load of carp instead!!
Dealing with the results from an EICR carried out by niceic ac contractractor at a commercial premise at the moment. 6 out of 7. Ccu"s have been condemned as C2's, no other reason given than combustable, checked for damage, ip, thermal, nothing. 7th escaped extinction due to having a non combustable enclosure, which has a plastic cover. Rang niceic tech line, other than things checked for not warranted. On a walk around with no testing or getting a ladder out or plate of ---- loads of C2's not on the report.
No logic sometimes.
No logic sometimes.
The board in the piccy above is semi combustible I guess !! Never seen a mishmash of sh1te gathered together like that though..
Insulated enclosures are very rarely a C2 in my book.
No logic sometimes.
There's no requirement for non combustible CUs in a non domestic installation at all.
No logic sometimes.
sounds like somebody fishing for remedials that are not required. they need reporting to niceic. fat chance of anything being done though as long as their subs are paid.
Reply to Why, just why !! in the UK Electrical Forum area at ElectriciansForums.net
Why is the word 'competent' being over used to describe what was once just 'qualified electricians' with experience? Is it to promote proving you...
Hi, plumber here so please be gentle (or take the p-ss ;) ), I am supposed to be installing a UV water steriliser for a customer. I have some...
Has anyone got experience terminating steel conduit from 1935 (so likely imperial measurements) into a new metal enclosure? This was the work of...
Hi. I'm in the process of getting my qualifications and am taking on some small jobs for family to try and get some experience in. Today I was...
Hi all, Been asked to quote an EICR on a fairly large installation. Approx. 400 circuits that are a mixture of single and 3 phase. This is across...
