Discuss XVision HD Pro CCTV Fault in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Strima
I have a customer who has a XVision HD Pro CCTV system that now fails to boot. It's a few years old and I have cleaned a lot of dust out of the system.
It will only get to 99% on the power up screen then dumps out and cycles through it's start up routine.
I have replaced the MB button battery as it's often a cheap fix but still have the same problem.
I suspect the hard drive has had it, unless anyone has any other tips before I replace it?
If you have tried switching it on and off again and hit it with a hammer then my fault finding skills are exhausted. :D
... my fault finding skills are exhausted. :D
Mine will be if you have tried unplugging the hard-disk and see if it moans.
(can still be a weak power supply -just unable to run whole system .... )
But there may be pieces of straw hanging out of my mouth !
(no experience with that model)
Everything powers up as it should, I do have a spare PSU lying around so I'll try running it from that.
Reply to XVision HD Pro CCTV Fault in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Evening all, I have a little conundrum I need to get resolved. I’ve moved an EV charger from a single phase board that was on a 40a breaker and...
Hi, We’re having problems with our Bosch serie 6 washer/dryer. It’s about 6 years old. The model number is WVG30461GB/03. It has begun to stop...
Hi all looking for some helpful advice I'm an Aussie so go easy on me, I have a good mechanical engineering head but first time plumbing and...
Last weekend I experienced a weird electrical fault with my 2010 Peugeot Boxer Van. A little background - the van is a 2010 Boxer 330 2.2 Short...
