E
extec
3 8.3 0hms is a lot better than 200 BUT with a bit of effort you can get this to >1ohm
How much effort are you talking about? I would be interested in how you achieve less than 1 ohm on a TT
A lot depends on the type of soil you're going to whack into. You need the biggest, fattest rods (note, not rod) you need to couple them together and drive them deep.How much effort are you talking about? I would be interested in how you achieve less than 1 ohm on a TT
I could put additional rods in I guess and hook them all together.
Depends on the soil conditions and available space.
I start with 2x 8' rods spaced at least 10' apart as a baseline for a small installation and take it from there.
Difficult to achieve if the installations are on terraced properties without garden space.
If you can't do that you need to look at tapes and plates and multiple rods.
It's not hard mate.
Aye that's a lot more effort than some of the jobs are worth for me I thought you may have discovered some way of making the job a lot easier.
I disagree, we live near a busy road into a fairly large town. We're on a TT with a sub 1 ohm RaAnd as we all know TT systems are normally a countryside thing.
If you aren't going to do the job properly then don't do it at all!
If it was available I'd have it done in a heartbeat mate, I've checked though.I did say normally in the countryside, not always.
Have you confirmed that PME is not available? I'm not suggesting that you should have it connected though, especially not with an Ra as good as that!
As I said earlier all of the TT installations I have come across around here within a reasonable distance of a town have had PME available. And since the connection by the DNO is free then I generally get it done.
Ha ha you can't seem to help yourself can you the job is done properly within the guidance set out in BS 7671
Any guidance given in BS7671 which relates to the numbty 200 ohm Ra values can be thrown straight into the nearest bin. At best it's referring to stability, and nothing beyond that. I take it from your posts above, that you'll also be using the equally useless 1.2m thin 3/8'' non-extendable twigs for your earth electrode installation, that basically can't ensure any stability to your ultra high Ra values too.... You'd do well to listen and take note of what has been stated above by those that Know what they are talking about!!
Do your customers a favour, ....Stay well away from TT installations!!!
Extec
