Discuss Testing tips or tricks in the UK Electrical Forum area at ElectriciansForums.net
I am currently doing maintenance on flats, when people move out i go in sort anything thats broken etc and do a EICR. This may be a stupid question but i want to know if yous have any little tricks tips or suggestions to speed things up when testing ?
Theres a guy up in Glasgow who should be able to give you a few pointers , he specialises in RCD fault finding ..
When you see him , ask him if the Grand offer is still available...
In a one word answer "experience" :)
How big are the flats? how many circuit? how much time are you allocated? how long are you taking?
...If i was to employ a tester,and they were both qualified and thorough,and one was slightly quicker than the other....i'd employ either of them. Now go forth,Grasshopper :icon12:
Get yourself a good routine on the go and you will soon fly through them.
I've spent the last 5 years solely testing ind and commercial as we don't do any remedial purely test a inspect.
But once you get into a good routine you will get much quicker only experience can help u really and the more you get the quicker it will become.
Learning max Zs and cable sizes for bonding are a great help as saves looking them up and obviously knowing cable size max current also helps but that's pretty easy to learn
Does he also specialise in one day rewires by any chance?... hence the specialty of fault finding.
When arriving on site and looking round flat to see what there is to test, also see if anything exposed/ damaged etc. Remove lamps and leave light switches in the ON position. Unplug appliances and or switch off. That way you are now prepared to test and saves doing it later.
Reply to Testing tips or tricks in the UK Electrical Forum area at ElectriciansForums.net
I sorted the fault fairly quickly as it happens but only because I'd come across it once before and at the time a few people said it couldn't...
Hi, I am just wondering if there is anybody out there interested in allowing me to do a little voluntary work with your company to gain a little...
Hi all I don't appear to be able to post in the DIY forum so apologies if this is the wrong place. I live in a block of flats with an external...
Friend of mines dryer machine has stopped working, 2 days out of warranty. I am trying to help theme out as money is tight for them however, I'm...
