Discuss The apprentice Question in the UK Electrical Forum area at ElectriciansForums.net
J
jp1976
a coil is connected to a 24v AC supply at 50 Hz. if the current supplied to the coil is 360ma and the coil resistance of 35(homes), determine the value of inductance
Let's have your answer first. We don't do homework but will help if you have a stab at it, remember to put your workings out up.
I'm not the apprentice just can't help him with it nor can the other 8 sparks that have seen it. It's been best part of 20 years since I did this stuff
X = 2ΠfL, where X is the reactance, f is frequency, L is Henrys ( not the vacuum cleaner, you muppets)
Not sure if this question is worded correctly? It's asking for inductance which would be the 35 Ohms already given. Unless it's asking for the value of the coil in Henrys which by transposition would be:
L= 35 / 2 x 3.124 x 50
= 0.11 H
= 0.11 H
not sure you have it there. work out the total impedance as X=V/I, then deduct the resistive part of the coil, then from the inductive impedance, work out the value of henrys a per the L=X/2Πf
probably using one of them new-fangled posh phones, the ones that ain't got red LED display like ours. download (1).jpg
which is the same 0.11 H
It's already given the value of total inductance as 35 Ohms (close to what you just got above).
So yea I'd say its asking for the rating of the coil in Henrys. The confusion is asking for the inductance which would be the 35 Ohms lol
no, it says the resistance is 35ohms ( or wimpeys)
a coil has both resistance and inductance. do'ntr need an additional resistor, unless for current limiting..
If it wanted Impedence Z = square root of R2 + X2
But thats if there was a resistor in the circuit as well as an inducter
I may be wrong its just I'm going through this stuff atm so it's all fresh in my head lol
I suspect the OP means the Impedance (Z) is 35 Ohms. (and purely reactive)
must be a superconductor. zero ohms resistance.
if the impedance was 35ohms, current would be 24/35 = 0.6857A. but it's not. ot's 0.360A
The coil resistance is 35 ohms.
Do a quick sketch of an RL circuit.
Make your observations of voltage and current.
Now transpose your observations to a vector diagram.
Does this help?
I would make a crap lecturer haha
The magnitude is all we're interested in here.
Plus, remember, I'm assuming the resistance of the coil is 35 Ohms.
We can do the complex (j) way if you want! :)
If we divide 24/.360 = 66.67, we know R = 35 so if we square root(Z2-R2) then Xl = 56.74
So answer is Xl = 56.74.
Xl= 2piFL, rearange Xl/2piF=L
So L = 0.18
Cheers
I stand corrected said the man in the orthopedic shoes!
Always prove your answer us what I was taught!
So I did and my original valuation appears to be nonsense..
Due to the fact that I am doing this whilst out drinking beers and trying to juggle the numbers and transpose the formulas in my head..
Rejigged my calcs as I discovered a silly fundamental error..
My new answer is 0.181780602109573 H.
Reply to The apprentice Question in the UK Electrical Forum area at ElectriciansForums.net
A coil is connected to a 100v a.c with 20ms, and supply current taken by the coil is 6a calculate the frequency (50Hz) the overall impedence (16.6...
Hi All, I am currently learning about AC and DC supplied coil and have been given the scenario below. I understand the first few steps but then...
When I joined this forum a decade or so back, there was a discussion going on about a welder that was connected with a 3-core cable to L1, L2 and...
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the...
I live in Thailand and my home has 240v, 3 phase power supply. I want to add an electric car charger but first want to determine what the outlet...
