Discuss Amendment 3- escape routes in the UK Electrical Forum area at ElectriciansForums.net
J.C.E
wiring systems in escape routes 521.11
reading a little into this- does this apply to domestic?
or just just larger buildings which can be class as BD2, BD3, BD4.
surface plastic trunking going across a ceiling to a pendant in a house- would this really require metal clips?
Across the top of the front door or back door, or n the hallway as described above. This regulation was devised to assist evacuation and fire fighting, so I can't see why it wouldn't apply in certain conditions.
how far do you go to define an escape route in a house? stairs? all doors?
Escape route defined in BS7671; path to follow for access to safe area in the event of emergency.
From Fire Safety; escape routes should be designed to ensure, as reasonably as possible, that a person confronted by fire anywhere in the building, should be able to turn away from it and escape to a reasonable place of safety. From there they should be able to go directly to a place of total safety away from the building.
I would suggest this means common access routes out of a domestic property, stairs, front or rear doors to the outside.
Reply to Amendment 3- escape routes in the UK Electrical Forum area at ElectriciansForums.net
I have a job coming up where I likely need to replace old twin and earth (imperial size) feeding one, perhaps two flats in a 3 storey converted...
hello, i am just about to completely rewire a refurbished house. i have done the same to several houses in the distant past. i have just read...
  • Locked
5K
Hi Guys I have been following this forum over a number of years reading endless discussions and picking up things along the way. I am a JIB gold...
4K
