Discuss copy of 16th ed- requirments for rcd protection in the UK Electrical Forum area at ElectriciansForums.net
J.C.E
has anyone got a link/pdf of the requirements for rcd protection in the 16th ed
-more for socket outlets
***sorry if its 25-30 years old- it would be 15th ed right****
As far as I remember later on in the 15th a socket that would be potentially used for outdoors required rcd protection and this was often done with a rcd socket outlet, no requirements were required for buried cables <50mm or other sockets not used for outdoors... its a while ago but it was something like that... rcd requirements then got stricter throughout the 16th and into the 17th to where we are today.
not sure if RCDs were specified for sockets under the 15th. basically it was bond everything metal and bang test.
what if a cooker circuit was installed at 15th edition (it has a socket outlet on switch- not rcd protected)
theres a 16ed board in there (poss put in at a later date)
and I am doing a eicr to 17th amd3
would you say 100% c3- if its not located right by back door- and there various rcd protected sockets between the non protected cooker socket and the back door.
I would recommend you call your schemes tech helpline and ask them.....
My house was built new and wired to the 15th.
I believe it was RCD socket available for use by outdoor equipment.
It had an Rcd socket in the garage, but nothing inside the house even tho' some were closer to the lawns.
If memory has me correct, there was no requirement for RCD protection. reg 412-06 to 412-06-02 (supplementary protection by residual current devices) is very vague.
Reply to copy of 16th ed- requirments for rcd protection in the UK Electrical Forum area at ElectriciansForums.net
I sorted the fault fairly quickly as it happens but only because I'd come across it once before and at the time a few people said it couldn't...
Question is does this DB really need RCD protection as there are only internal lights and sockets supplying this large building that used to be a...
Can anyone tell me the latest regulation for RCD protection on socket outlets, I believe it's required for sockets up to 32A but I'm told it...
Hi all, Just a quick one regarding the need for RCD protection for socket outlets rated up to and including 32A. I have been tasked to install...
So here is the thing Rhere is an old MEMSHIELD TPN+E Board that is pretty mich obsolete. The only place that sells their breakers would be Ebay...
