I don't normally work on refurbishment so excuse my ignorance.
If you were moving a socket, and the circuit isn't currently protected by RCD, do you need to install one.
The circuit is currently fed from an old DB protected by cartridge fuses. The circuit is wired in pvc/pvc single core conductors and runs in steel trunking and surface mounted steel conduit, which drops to serve a surface mounted metal clad socket in an office.
