L
Leesparkykent
Doing an unoccupied rewire on a house for a builder and part of that was running the cables in for a intruder alarm. finished of the snagging today and the customer has asked if I would mind fitting the alarm as they've been let down by the person who was supposed to do it. I had a look at the kit they've ordered and they have a premier elite 24 panel but texecom reflex pir's.....Am I right in thinking these pir's are normally open? If they are then obviously wont be compatible using double pole end of line method as they need to be normally closed. can any one confirm this? Cheers lee
they are same as any other pir. n/c going open in alarm. ( usually a meter across the alarm terminals will show around 10 ohms). you can wire conventional alarm and tamper or fit eol resistors.
Tel I cant work it out... I started rigging the panel up at home to see if they would work before I posted here ....4K7 resistor in parallel across alarm terminals and and 2K2 in series across tamper. So blue from panel in to 1st alarm terminal at pir, 4K7 resistor across alarm terminal, 2K2 from alarm terminal in to tamper, from other tamper terminal to panel. programmed as double EOL but comes up as active when trying to set it? any ideas? cheers
Texecom premier elite compatibility
Leesparkykent,
Leesparkykent,
