Discuss Help! Damsel in Distress! in the UK Electrical Forum area at ElectriciansForums.net
My immersion heater wall switch gets hot when switched on. Water heats OK but switch gets hot. So, until I know what is causing this, I obviously don't use it. Any advice most welcome pls!
a number of possibilities
1. it may be normal to get warm in use.
2. may be a poor connection or a tired out switch.
you need an electrician to visit to establish what it is and rectify if necessary.
a few of us local to manchester. one of us may be able to help.
leave switched off until sorted.
More than likely a loose connection at the switch, get a Sparky in ASAP to take a look, if he is a decent Spark shouldn't cost more than a standard call out plus the cost of a replacement switch, less than £100 much less ask the Spark what his call out charge is, tell him the problem, he will probably have a new switch in his van, better that calling the Fire Brigade.
Forgot to add that last bit on my post, good call Tel
Is anybody else have bloke pictured messing around with a boiler in these threads? It started off for me with that threads Plumbers are great!
PS God knows what's going to appear next, with the title of this thread. Her indoors is not going to believe me.
Many thanks to all of you for your quick response! I will get an electrician in to look at it. Just wanted to clarify that it is probably the switch that is the problem. It will remain strictly in the "off" position until resolved! Very much appreciate your advice - thank you.
estimate if it were me would be £65, including a test of the circuit to ensure there were no other faults.
I'm off, before her indoors sees this picture on my PC screen.
images
Nice to see she's got you well trained Middy :p:D, my missus won't let me in her kitchen to do anything. Reckons she can't find anything once I've put it away ;):).
I can't go into ours in case I leave a mess, and we all know Sparkies, even retired ones are the tidiest folk on this Planet:cool::p:D:rolleyes:
Know exactly what you mean Pete, mine came up with a cracker earlier. She told me I hadn't cooked Chinese in ages, how can I cook when I'm not allowed in the kitchen ? :confused::(.
Odd things, Women
on the whole, present company excepted, if you try to explain anything to a woman that does not involve shoes or handbags, they never listen.
Shoes... you mean work boots? Handbags... never big enough for a decent selection of kit, much prefer a toolbag or rucksack :D
Hate to say it, but I know exactly what you mean. Used to dread inane conversations about trivial carp like fashion, make-up, diets and the latest series of Celebrity this and that.
so obviously, you'd prefer to shop in toolstaion rather than primark.
Reply to Help! Damsel in Distress! in the UK Electrical Forum area at ElectriciansForums.net
Calling all electrical professionals / boiler tradesmen -WE NEED YOUR HELP! Every so often (twice in the last two days) when running the hot...
Hi, need more advise as getting two different views from electricians. Ty Detached double garage 10m from house, split equally into garden room...
I have taken delivery of an undersink water heater. It is fitted with an RCD on the electrical supply cable which terminates with a euro-plug. I...
I'm looking at a vending hot drinks machine 2.9kW that has a thermostatically controlled hot water tank permanently attached to a water supply...
