S
Specialist
i can't read and i can't write,
but i can drive a tractor.![]()
Oh bugger, I can't drive a tractor
Yes mate I have something in my workshop something I made when my then boss asked me to do the impossible a wand I think it's called, don't know if any wholesalers stock them.
I'm done.
I'm done.
To the OP, not you Andy Don't think we are being harsh on the UE unidentified electrician, come clean mate you will be doing the work wont you? you're the mystery Sparky, if this job actually exists, you need to call an Electrician pronto, not angle for info on this forum, Ive enjoyed our little chats but enough is enough, get real. I think I'll join Specialist and be done as well.If he knew what he was doing, he wouldn't have been wiring the pendants in singles in the first place. Going on what you've written, neither you or your Electrician (If he exists) have the first clue what your talking about. Your just fishing for information.
I'm done.
OP.... You'll be happy to know, I'm STAYING..... I won't abandon you like the others. Just need some popcorn....
I will however get to the bottom of it even if nobody helps.
Are you putting a CU in the garage, that seems to be missing.
Turncoat, 5th columnist, trouble makerOP.... You'll be happy to know, I'm STAYING..... I won't abandon you like the others. Just need some popcorn....
Turncoat, 5th columnist, trouble maker![]()
i am not doing this myself, I would also not mention it again.
Not read all the replies... but non fire rated downlights?
not necessary unless the ceiling is the boundary of a fire compartment. e.g. in a garage with a room above, or if the room/s above are separate dwellings.Not read all the replies... but non fire rated downlights?
