duffielddan
I recently bought a 12V Whale Gulper 220 waste water pump to remove water from a shower on the groundfloor of my house in Germany (no way to gravity empty the bath/shower.)
I am after advice on if I have the correct 240V AC to 12V DC transformer.
The pump is a diapragm pump and the instructions state the following:
Voltage 12 V
Recomended fuse size: 5Amp automotive (supplied and fitted)
Dry running Current: 2.4A
Current draw: 3.5A
The transformer I fitted is described as the following
Waterproof LED supply
Model 12V60W IP67
Input AC 100-240V, 47-63Hz, AC 1.67-0.56A
Output DC 12V +/- 5%, DC 5A, 60W.
The pump works but only runs at 2 L/min when it should run at 10+ L/min. I am fairly confident the pipework is not an issue. (no blockages, pipes big enough etc)
Before I go back to the manufacturers and complain could someone tell me if my transformer is likely to be correct or if I am missing something.
Many thanks for any help,
Duffielddan
Voltage 12 V
Current draw: 3.5A
Model 12V60W IP67
Duffielddan
