Discuss BELL WIRE FOR RING PRO DOOR BELL in the The Welcome Forum area at ElectriciansForums.net
LEEBOY
HI GUYS AND GIRLS,
LOOKING TO INSTALL A RING PRO DOORBELL WHICH IS POWERED BY A 3 PIN UK TRANSFORMER NOT FROM A CU .
MY QUESTION IS WHAT BELL WIRE TO USE PLEASE.
REGARDS LEE
HI GUYS AND GIRLS,
REGARDS LEE
What voltage does the bell operate on?
The ring pro website recommend 20awg bell wire which is obviously american gauge wire but haven't got a clue as where to start with uk bell wire.
regards lee
20 awg is 0.52mm. Standard bell wire can come in various sizes and 0.50mm is one of them so this should suffice.
thats great, thanks ever so much for your help. Is there any problems chasing the bell wire into a brick wall or surface mount only.
regards lee
thanks for all your help. Clicking on the link brings me to a general search so dam i safe to say most standard bell wire will be ok.
regards lee
regards lee
No reason why you cannot chase it into a brick wall but check it functions before you fill the chases as the small conductor is fragile. You can surface fix but the clips are small and are okay fixing to wood but brickwork they will be hard to fix and because the nail is short it is liable to fall out of plaster work finishes.
thanks ever so much for your help. Because its small i wanted to chase it as opposed to fixing it as it seems it would be fiddly and probably damage it along the way. thanks again for all your advice today.
just have a look on the ring website, they have all the info you need to install one and if you want it mains powered instead of battery it can give you a list of compatible powered door bell chimes that can feed the power to the ring device itself
personally, i'd use a bit of belden cable. it's tough as pete999's false teeth. :D
Thanks all. Forgot to say there is no existing bell cable or transformer at the CU hence why I'm going with the mains plug in transformer.
regards lee
sorry, pete. just my warped sanse of humour. no offence intended. :D
regards lee
Of course you could always use a wireless bell.
You don't have to use thin bell wire, if you plan to bury it in plaster I'd consider something more robust that includes an outer sheath.
regards lee
Where are you intending to fit the transformer Lee?
Hi PETE,
TRANSFORMER IS ALL OF TWO METRES FROM THE FRONT DOOR , SJD SUGGESTED NOT USING BELL WIRE
So you intend plugging it into a socket, run the output cable up the the bell and from the bell to the push, correct?
HI PETE,
NO BELL TO WIRE FROM OR WIRE TO. I HAVE NO EXISTING BELL TRANSFORMER OR PUSH AT THE DOOR. THE PRO DOES COME SUPPLIED WITH A CU TRANSFORMER BUT I WONT MESS AROUND WITH ANYTHING AT THE CU HENCE THE STAND ALONE TRANSFORMER PLUGGED INTO A SOCKET THEN POWERED FROM THERE TO THE BELL, THE WHOLE DISTANCE IS ABOUT TWO METRES, REGARDS LEE
HI PETE,
It may be age, but you have lost me Lee how does this pro bell thingy work then
Hi PETE, OK HERE GOES :IF YOU HAVE AN EXISTING BELL/TRANSFORMER RUN FROM CU ITS A TWO MINUTE OF PUTTING IN A SUPPLIED CABLE IN THE EXISTING BELL AND WIRE UP BELL AT THE DOOR JOBS A GOOD UN. THE PRO RUNS AT 24V AC AND PRETTY MUCH ALL UK BELL TRANSFOMRERS RUN 12V AND THATS NOT ENOUGH SO SUPPLIED CABLE HELPS YOU USE EXISTING BELL BUT THE SUPPLIED DIN RAIL TRANSFORMER MUST BE CHANGED AT THE CU . I HAVE NEITHER EXISTING BELL OR TRANSFORMER AT THE CU , SO THE QUICKEST WAY FOR ME AND SAFE WAY IS THE BELL CAN BE RUN FROM A MAINS PLUGGED IN TRANSFORMER . TRANSFORMER TO RING PRO AND READY TO GO ,INCLUDED IS A WIRELESS CHIME AND IS SET UP OVER WIFI WITH THE BELL . REGARDS LEE
Thanks, so your original question what bell wire to use and buried in plaster, ordinary bell wire will be OK as per my original post.
THANKS PETE FOR ALL YOUR INPUT OVER THE LAST COUPLE OF DAYS.
REGARDS LEE
Hi Lee, I am also thinking of installing my ring pro with a plug in transformer. I am in the uk also, could you give me any advice on your installation, how it went, also could I ask you which plug in transformer did you use and where you purchased it from, as I am having difficulty in locating one to use. Thanks.
I think Lee is long gone why don't you start a new thread.
Reply to BELL WIRE FOR RING PRO DOOR BELL in the The Welcome Forum area at ElectriciansForums.net
Hope you're all well . I've had ring door bell 2nd generation hardwired for 1.5 yrs... it was connected to transformer which is connected to the...
Hello, I would liked to install a Byron wired doorbell with built in chime and 8v transformer. I'm struggling to get power source. I have a...
Hi, A lot about this fault confused me to be honest. So customer complained the doorbell was not working as intended. By that I mean the chime...
Hi, I bought a Ring wired bell thinking, easy, just replace the current doorbell. Now I'm hunting down how to bypass the chime but am unsure of...
I’m trying to install my Ring doorbell (2nd gen) and I’ve discovered that the transformer feeding my Freidland isn’t producing any power. I...
