Deleted member 26818
That length of run, you’re looking at 10mm2.
Could make off into adaptable boxes and then spur off in 2.5mm
Pretty much, but at least they know they wont get more than 32A from the circuit. i think the idea is much like a cleaners circuit, you know that only 1 or 2 will actually be in use at a time.Again, I'm probably misreading this but, am I correct in that they have asked you to design these 8 RFC (40 sockets) but are not willing to clarify what is being plugged into them?
Okidokie, thanks for the help. I was planning on using a 6x6 JB and coming out of there into the socket so I'm along the same lines of thinking as you.That length of run, you’re looking at 10mm2.
Not much help really, but you are welcomeOkidokie, thanks for the help. I was planning on using a 6x6 JB and coming out of there into the socket so I'm along the same lines of thinking as you.
Many Thanks
yeah my main incomer is 400A Switchboard, i've then got a 3ph DB in each stand.Is three phase available?
Could you run a supply to a point then supply temprary rubber bricks for 16 amp distribution?
At a guess these are for food style outlets such as burger vans which mainly run off 16 amp commandos.
I've not even approached the subject yet with them over if they want to sockets locked so punters don't start charging their phone or fire up a 3 bar Electric fire for the winter games haha
I'd be suggesting to the customer they invest in getting a consultant in to do a proper spec.
It would depend upon the make, but 6mm would be the limit for termination in box and terminalsJust out of curiosity, why SWA for wiring the sockets?
How to you terminate the armour?
If it is 6mm then you will have fun putting 2 of them into each socket.
a 25mm SWA is needed, which obviously inst viable for a few sockets.
