Discuss Testing electrical socket in the UK Electrical Forum area at ElectriciansForums.net
Bori
I recently bought 1 gang British electrical socket. Before wiring it up,is it possible to test whether the socket work? I tried to use a multimeter using the continuity test by connecting it to L and N but there is no sound coming. Does that mean that the socket is broken?
Get an electrician in to fit it for you, you obviously have no idea of what you are doing.
A wind up?
You could test continuity between the live input to live output and the same with the neutral and earth. Not much point if its new though...
Since when did 1 gang 13 Amp sockets have input and output terminals?
PS Spot the OP's location
a thread will only give continuity if it is wet,metallic, or pi$$ed on
Appalling Thread, OP-----------you are dismissed
This thread has made me smile on a dreary Monday morning...
You have some funny ways of testing sockets mate... Do none of the customers complain??
I have a sick aunt who needs 1000000 rupees for her operation so please send international bank draft urgently.
Reply to Testing electrical socket in the UK Electrical Forum area at ElectriciansForums.net
Hi, I replaced an outdoor electrical socket recently with a 2 gang, BG socket which has LED lights to show when it is switched on. Since then I...
Good day. First time poster. We recently had an electrician perform the EICR, as this is a newly purchased property I thought'd I would have the...
Hi, This post is about my concerns with medical IT socket outlets and want to alert you all if you are fitting them in a hospital. The current...
Hello all, I hope you're all keeping well. I have a question regarding insulation resistance testing. Whether doing a single circuit IR test or...
