- Jul 15, 2016
- 23,301
- 1
- 29,151
- 315,788
- United Kingdom
- Electrical Engineer (Qualified)
i' gotta come over and have a nosey at that. 11.00am one day is good.pubs open at 12.I'm too knackered, it'll do it tomorrow ???
[automerge]1567880192[/automerge]
I don't care if I not cool, my body is screaming at me ?
You're heading for a ban if you don't get them covers off?
Or engraving. This has been in HA specs for many years also where it is not obvious what the point of isolation does.One miss-aligned label aside, I wouldn't be panicing if I saw that cu! From the outside at least. Also, who is labeling FCU'S in domestic kitchens?
With age comes the wisdom ,when not to disturb a can of worms ,half asleep !I'm too knackered, it'll do it tomorrow ???
Awful job MateThought i'd nosey at the heating controller, standard RF setup
Then I nosey under the boiler. ..
View attachment 52002 View attachment 52003
Thoughts? It might look innocent and be so but the unconnected earth's male me wonder...
a typical wet-arse install.Thought i'd nosey at the heating controller, standard RF setup
I’d be most concerned that it’s Wylex ?
If this install gives you such concern you’ve had a sheltered electrical life thus far ?
What's wrong with wylex? I think they make good fuse boards.I’d be most concerned that it’s Wylex ?
they even do some with MCBs.What's wrong with wylex? I think they make good fuse boards.
You don't see them at wholesalers a lot these days.What's wrong with wylex? I think they make good fuse boards.
i like the BG boards with compact RCBOs. no earth tail either,I prefer RCBO's
Most brands do compact rcbos now, with no functional earth. Bg is ok for a budget, but I would rather use hager or wylex. They look a bit more professional imoi like the BG boards with compact RCBOs. no earth tail either,
