The point I'm trying to make is that you don't need the exact data from the manufacturer of one charging system, you need an idea of the typical output from a motorcycle charging system. This way you can see if it is anywhere near the current you need.
This will save you waiting for a manufacturer to reply, which may take longer than normal with things as they are.
Also,do some research into the difference between Amps and Amp Hours. This will help you understand figures that you are seeing.
Ah OK yeah,
As for the difference between Amps and Amp hours,,, ANYONE CARE TO ENLIGHTEN ME PLZ TIA
[automerge]1587372712[/automerge]
Ah OK yeah,
Ok so I'm not having much luck with actual specs from engines, probably using the rwrong search term
But this guy says this :
[automerge]1587372982[/automerge]
Ah OK yeah,
So he's saying he has 400v... Which is followed up by some other guy calculating that it's at 28A
For my (theoretical) motor it is a 72v motor
As a electric mathematic dunce... Can I then say
(400v ÷ 72v) X 28a ///// 5.55 x 28 = 155. 55
Or is that just nonsense?
[automerge]1587373066[/automerge]
[automerge]1587373274[/automerge]
[automerge]1587373388[/automerge]
In the measurement of electricity,
amps are a unit of electrical current;
amp-
hours are units of current storage capacity. ... An
Amp-
Hour is a more abstract idea, multiplying an amount of current by a period of time: one AH
is defined as an
amp of current flowing for one
hour.
Sciencing - https://sciencing.com › relationship-...
What Is the Relationship Between Amps & AH? - Sciencing
[automerge]1587373465[/automerge]
amp-
Amp-
is defined as an
hour.
