Yes, mine are RCBO protected.
Thanks for that info. (I don't dare start a thread here on sockets and switches in bathrooms?). Should I assume that other French homes are not RCBO protected?
In the interests of equality and diversity what about white pudding:D:D
Or a red pudding?
Or a smoked sausage?
We have to cater to all tastes here!
Or a red pudding?
all tasres maybe, but not the vegans. they originate from the planet Vega and are aliens beyond our comprehension.
I have never seen an RCBO in any other French home, but they do all have at least three RCD's most have four.
4 RCDs??? similar to the number of reverse gears on their 1940 tanks.
You must be thinking of the Italians.
As the regulation restrict the amount of MCB's per RCD (eight) and the requirement to have separate radials for most white goods and other items the amount of RCD's soon mount up and lets face it we in the UK where very late in realising we should have two.
I did know a lady who turned vegan who was quite tasty. No Chianti, before you ask...
Wouldn't have made any difference anyway, the Gerries were behind them as well.....so much for the magnificent Maginot line.....we'll just go round it. :(
Maginot Line was a waste of time. they should have built it as a ring, not a radial.
see what I did there. brought the thread back on topic.
  • Optimistic
Reactions: pc1966 and DPG
Well at least there was a strong Resistance, must have been a circuit of some sort.
you need to speak to Rene about the resistance... listen carefully. I shall only say this once.
  • Funny
Reactions: SJD
Only ‘wernce’. You’re itching for the Madonna with the big boobies.
"Good moaning" "You stupid woman, I was giving her the kiss of life"
Still undercover, I see, Mike.
Are you mistaking multimeters for the Multi Function Testers (MFT's) we use for installation testing, we still use the standard multimeters but these are not capable of carrying out the tests needed to verify an installation
You've got a good point, can't do a megohm test with a multimeter.
To be more specific, as an electrician (installer), we're not required to do these loop tests, megohm tests on houses, last I knew anyway. I have been required to do these in factories for certain circuits as well as for feeders. On some jobs, ie: power plants, chip fab plants; we did have crews "commissioning" EVERY circuit, including feeders.
There is a very strong requirement here for dead testing before the circuit is energized, both for a full installation and for simply adding a new circuit to an existing system. That applies for domestic, commercial and industrial stuff.
Not just IR testing to see if the cable is OK, but also testing R1+R2 (live and earth resistances) both to verify socket & SP switch polarity, and also from the boards Ze (earth loop impedance) to check the circuit's Zs value is going to allow fast enough disconnection by the choice of fuse or MCB, etc.
Website
https://www.scolmore.com/products/deco/
Manufacturer / Distributor / Supplier / Inventor - etc
The Ring is dead, long live the Radial!⚡
Scolmore,
static zap,
