Yes, mine are RCBO protected.
Thanks for that info. (I don't dare start a thread here on sockets and switches in bathrooms?). Should I assume that other French homes are not RCBO protected?
In the interests of equality and diversity what about white pudding:D:D
Or a red pudding?
Or a smoked sausage?
We have to cater to all tastes here!
Or a red pudding?
all tasres maybe, but not the vegans. they originate from the planet Vega and are aliens beyond our comprehension.
I have never seen an RCBO in any other French home, but they do all have at least three RCD's most have four.
4 RCDs??? similar to the number of reverse gears on their 1940 tanks.
You must be thinking of the Italians.
As the regulation restrict the amount of MCB's per RCD (eight) and the requirement to have separate radials for most white goods and other items the amount of RCD's soon mount up and lets face it we in the UK where very late in realising we should have two.
I did know a lady who turned vegan who was quite tasty. No Chianti, before you ask...
Wouldn't have made any difference anyway, the Gerries were behind them as well.....so much for the magnificent Maginot line.....we'll just go round it. :(
Maginot Line was a waste of time. they should have built it as a ring, not a radial.
see what I did there. brought the thread back on topic.
  • Optimistic
Reactions: pc1966 and DPG
Well at least there was a strong Resistance, must have been a circuit of some sort.
you need to speak to Rene about the resistance... listen carefully. I shall only say this once.
  • Funny
Reactions: SJD
Only ‘wernce’. You’re itching for the Madonna with the big boobies.
"Good moaning" "You stupid woman, I was giving her the kiss of life"
Still undercover, I see, Mike.
Are you mistaking multimeters for the Multi Function Testers (MFT's) we use for installation testing, we still use the standard multimeters but these are not capable of carrying out the tests needed to verify an installation
You've got a good point, can't do a megohm test with a multimeter.
To be more specific, as an electrician (installer), we're not required to do these loop tests, megohm tests on houses, last I knew anyway. I have been required to do these in factories for certain circuits as well as for feeders. On some jobs, ie: power plants, chip fab plants; we did have crews "commissioning" EVERY circuit, including feeders.
There is a very strong requirement here for dead testing before the circuit is energized, both for a full installation and for simply adding a new circuit to an existing system. That applies for domestic, commercial and industrial stuff.
Not just IR testing to see if the cable is OK, but also testing R1+R2 (live and earth resistances) both to verify socket & SP switch polarity, and also from the boards Ze (earth loop impedance) to check the circuit's Zs value is going to allow fast enough disconnection by the choice of fuse or MCB, etc.
Me thinks they do things slightly differently in the US. Might be wrong.
  • Funny
Reactions: Maji236 and DPG
USA use the tried and trusted 3fold Test. :) .
1.it works.
2 it not work.
3. it goes bang.
first 1, fine.
2nd one call supervisor.
3rd one run away.
Radials are usually quicker to install and quicker to test - so cheaper on labour, material wise breakers are same price and cable works out about the same or actually cheaper without the return leg.(Eg 30m of 4mm or 60m of 2.5mm) I do mainly commercial and use 25a 4mm radials a lot for runs along store walls etc. Also wiring rings in singles in containment is a massive pain to keep the right “leg” together and also twice as many drums to get tangled up and wrapped round your ladders ? rings have there place still, probably make more sense in houses and offices kitchens etc
When we buy a house later this year .I am doing a radial rewire . Might mean a huge consumer .But if possible will make every room radials etc
my preference is rings for kitches/utility rooms. 2-3 radials for rest of house. (average house, not a mansion).
All socket circuits fitted with £150 AFDD as 18th Amendment 2 is looking like?
I built and wired my own house around forty years ago. If I could go back, with what I know today, each kid's bedroom would have had its own radial and MCB.
And coin meter ?
Reactions: static zap
1.it works.
2 it not work.
3. it goes bang.
4 If you are lucky something smells funny ,
and the AFDD has tripped.
(no, was just customer breaking wind when heard price.)
Website
https://www.scolmore.com/products/deco/
Manufacturer / Distributor / Supplier / Inventor - etc
The Ring is dead, long live the Radial!⚡
Scolmore,
static zap,
