S
stormtrooper677
Hi, Could you please give me some advice - I have the veritas 8 alarm with keypad and today I had to turn the mains off to do some diy work. When I turned it off within 2 minutes the alarm started beeping and the alarm went off inside and outside the house. I tried to reset it but it wasn’t having any of it. It eventually stopped going off of its own accord. However the alarm panel is now frozen with 7 of the 8 zone lights showing as red, along with the tamper light flashing red and the unset is steady green. The keypad won’t take any numbers and is dead and won’t reset for me and the box outside the house is still flashing away but not making any noise which is good for the neighbours and my sanity. What is the best thing course to action for me to take now to get it back to normal.
And probably a new battery !!
The panel requires a full nvm reset, so consult the install manual
Hi - thanks for your reply, forgive my ignorance on this matter as i am no expert on alarm/panels etc, but how would i carry out the nvm reset you mention for the alarm? we have no user manual to refer to as alarm already installed when we moved in.
Thanks in advance.
Thanks in advance.
I would probably try and get the alarm manual, I did notice most products in screwfix online have a link to download a pdf manual and if they sell the veritas then your sorted,failing that try veritas own website or google.
Ps if you find the manual you may feel able to undertake the procedure,if you are not a competent electrician BEWARE you could very easily trash the panel and need to replace it or worse you could get electric shock. For these reasons I would recommend you consult a competent electrician/alarm engineer.
Hi
try disconnecting battery then mains.
Count to 10 then connect battery black then battery red.
Panel should bleep all leds lit.
Put your code in.
Tamper showing.
Put panel lid on .
Connect mains.
Press reset .
If not ok now sounds as though panel shot.
An NVM (factory reset) is the only way to reset a locked panel, hence the manual so the OP can program his own settings and code
Hi
Put your code in.
Tamper showing.
Put panel lid on .
Connect mains.
Press reset .
Hi
Put your code in.
Tamper showing.
Put panel lid on .
Connect mains.
Press reset .
Hi - my thanks for all replies regarding this little problem i had - particularly plantpots step by step guide which has helped me set the alarm back to normal for me! I also intend to now purchase a new battery for the alarm with. The one in situ is a 12v 1.2ah giving a backup of an hour if required - however would i be ok to replace this with a 12v 3.4ah to allow more back up time if required?
Cheers!
Glad you sorted it .
I know a 2.1ah fits.its the pysical size of 3.4 that matters as they all vary in shape and size.
Cheers!
You can fit up to a 7AH battery in a Veritas panel
Plantpot - i took your advice (again) and stuck to purchasing a smaller sized ah battery and this fits fine into the panel - so am now fully sorted with alarm back to normal and back up. Many thanks again for your time with the issues i had - it is very much appreciated.
Cheers!
I'm having a similar issue, I disconnected mains power and battery back up to enable me to replace the remote keypad, when I have reconnected the power the alarm is constantly sounding and will not reset at all
I have a similar problem. I disconnected mains power and battery back up to enable me to replace the remote keypad, when I reconnected the power the alarm is constantly sounding and will not reset at all, any pointers are appreciated
Have you checked all the fuses
I have reset it now with the engineer code but am unable to arm it using my personal code, it will arm in a fashion by pressing part/full but flashes up zones 5,6,7 whilst arming
are those zones disabled/unused?
No the zones are as follows
1 Hall
2 tamper
3 kitchen
4 tamper
5 lounge
6 tamper
7 shed
8 tamper
try the engineer code backwards. if it works, that is your default user code.
It works but it doesn't, it still flashes zones 5,6,7 whilst arming and behaves a bit erratic when the pir detect
Problems with veritas 8 alarm
stormtrooper677,
Ianto218,
