Discuss Advice needed please for Electrics DIY - air vent in bathroom in the UK Electrical Forum area at ElectriciansForums.net
Hi all
DIY newbie here so advice needed please!
Moved into a new house about 6 months ago - there is an air vent in the bathroom which isn't working. We took lid off this afternoon and cleaned it out - it's an AXS100TR/NDX100T model made in UK.
It's connected up somewhere but how do I know if it's turned on and not working, or not on at all etc? If I wanted to get it working what would I do?
Any advice gratefully received - cheers fellas :)
James
Here is a photo
Welcome to the forum mate.
Looks like this fan is in the ceiling, is this correct?
It looks like the cables go out and up into the ceiling. Is there access to above the fan, in the loft?
Is there a pull switch inside that bathroom that isolates isn't for the light or shower? Or an isolator switch outside the bathroom?
Oh, and I like your songs....
If you have a suitable voltage meter and know how to use it safely, you should be able to measure if there is power at the fan, the terminals are under the circular lid that pulls off in your photo IIRC.
Maybe obvious, but have a look above the outside of the bathroom door and see if there is an isolator like this.
It could also be in an airing cupboard or the like.
Thanks :) there is access through the loft - no pull switch inside the bathroom or isolator switch outside the bathroom tho
If there is access to where the fan outlet in the loft then see if you can see the wires going to the fan and follow them, if you are comfortable doing that. See where/what they wire to.
Reply to Advice needed please for Electrics DIY - air vent in bathroom in the UK Electrical Forum area at ElectriciansForums.net
Hi Everyone, This is my last question/post for tonight, promise. Please can I ask for a little advice on certificates as I am now questioning...
I'm Ronald Alliy Thanks for the ability, in joining and posting on the fly. Check out my first post in the Diy...
hi all im seeking some advice on what to do next, I have been in the electrical industry for a while but have enrolled onto a collage with my...
