C
cybasmith
I have a unique problem which a licensed electrician could not solve. I have a 110 sub panel in my small shop for the garage and shop. It feeds off the main panel in the house and has been there for 30+ years and operating OK. Within the last year or so occasionally the lights in the garage would strobe when turned on. I called an electrician who couldn't find any problem and threw up his hands.
Now yesterday the florescent light in the shop wouldn't work. I cycled the breaker and it started working but then quit. When I checked it with my meter it only read 56 volts AC at the breaker. Just as an afterthought I went into the attached garage and turned on those lights and they strobed! When I checked their breaker (single pole) it was reading 56 also! The other three in the panel showed 110. I went to Lowe's and replaced the breaker for the shop light and it worked fine. Later I went into the shop AND NO LIGHT! It was late so I went to bed but in the morning the shop light was on and the breaker read 110. I cycled the light and it would not turn on and measured the voltage and it was 56.
Any clue?
Thanks, Ernest Smith
Any clue?
