HappyHippyDad
Supporter
Dec 18, 2011
5,378
6,731
405,788
Gloucestershire
The board in the picture below has 2 x RCBO's in it, they look like matches so I'm guessing schneider is the new merlin gerlin and that these RCBO's are a perfect fit?
However, Schneider seem to do other RCBO's. Easy9, acti9 and others. The Acti9 looks like it may fit this board but it is more expensive than the easy9. Will the easy9 fit? Also, will the acti9 fit? Will other schneider fit?
Bloody RCBO compatibility!
This has been on 15 minutes and no answer from Westward. He's slipping lately.
Come across this quite often at work. Acti9 iC60H’s yes, Easy9 no is usually the answer.
There’s a FAQ answer from Schneider with that somewhere as well, I’ll try to find it.
Typically I can’t find the answer where they specifically say the iC60H is the replacement, but they have a product selector for older items that gives the iC60H as a replacement for a C60H.
Product Substitution
There’s also this FAQ answer where they confirm iC60H is the new range with the same size and form factor.
Reactions: HappyHippyDad
with Stanley's help, it will fit:
I think the easy 9 are handed the other way ie bus bar on the bottom for domestic. I believe you need the active 9 ones for industrial DBs
HappyHippyDad
Supporter
Gloucestershire
Which RCBO fits this merlin gerlin multi 9 board?
HappyHippyDad,
Strima,
