- Apr 29, 2010
- 1,693
- 420
- 101,758
Hi Guys....
Just after any pointers if I may have missed anything, bit of a head scratcher ?
Got a new kitchen lighting circuit we've run in right back to DB/ new DB installed.
Have Megaman GU10 lamps installed (140504) and now and again mid range through dimming they strobe, min level ok no flickering.
We've tried 2 x types of dimmers now which have worked fine on these lamps for years on all other jobs:
Aurora DSP400x
Zano ZMO150
Swapped over RCBO in DB in case any issues with this.
Lighting feed is supplying a 2g dimmer switch.... both switches are affected.
Possible try some different lamps - Phillips and/or different dimmer thinking of a Varilight ?
Any help appreciated ?
Cheers Sy
Aurora DSP400x
Zano ZMO150
Cheers Sy
