Discuss changing consumer unit from plastic one to metal in the UK Electrical Forum area at ElectriciansForums.net
Not necessarily.
While plastic is no longer allowed for new domestic installs since 17th amendment 3, if it meets all of the requirements for being a sound installation (see Best Practice Guide #3) on inspection/test AND you can still get compatible parts then you could just add another MCB/RCBO.
Not necessarily.
Thank you for the answer.One more thing,I know plastic cu is not longer allowed in houses or flats,but what about garages or generally outboildings,are plastic cu allowed in there?
I think any buildings that are part of the house (e.g. attached garage) or might have folk sleeping (e.g. furnished conservatory, etc), would be covered. A shed or similar fully detached area only used for occasional stuff (probably 2m or so separation?) might be OK, but ideally just stick to metal CU for any new stuff.
Someone else on here with more knowledge of fire regs, etc, than me might be able to give more info.
The reg in question (421.1.201) says "Within domestic (household) premises" for non-combustible CUs, but doesn't have a definition for domestic (household) premises in part 2 so make of that what you can.
Crabtree believe it to include:
Typical Domestic household premises would include single and multiple occupancy homes such as Houses, Bungalows, High Rise & Low Rise Flats, Apartments, Student lets, Sheltered Accommodation, Farmhouses, Houseboats, Static Homes, Home Office, attached Garages, Workshops and Detached Summerhouses etc.
but that doesn't mean they are 100% right.
Detached garages/workshops are often better with metal fittings anyway due to robustness so it's probably safe to assume anything in or around a domestic house should be metal.
As already said though, adding a new circuit in an existing enclosure does not require it to be upgraded, provided you can do so safely - with compatible parts, etc.
It is actually still possible to use plastic CUs, but only if they are enclosed in a non-combustible cabinet or enclosure - and some are or were available, but often at more cost than putting a metal consumer unit in to start with.
Not sure myself whether the internal Mantel cupboards that are built into brick walls would comply as a non-combustible cabinet...that might be an interesting one to argue over whether a plastic CU would be acceptable in it....
Reply to changing consumer unit from plastic one to metal in the UK Electrical Forum area at ElectriciansForums.net
Ok, most new Consumer unit seem to come with a 63A RCCB and two MCBs. Most house consumer units now will also have RCD of some type be it a dual...
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
I want to know if my consumer unit (together with the digital meter) which is in a special metal container let into an outside wall near the...
Hi Everyone, Last year arranged for my mother's and my consumer units to be changed by the same electrician who is NICEIC registered. Both jobs...
Hi all, what is the best way to configure surge protection in domestic dwellings when you have multiple consumer units? Does each consumer unit...
5K
