Discuss Galv conduit question in the UK Electrical Forum area at ElectriciansForums.net
Hi. Is there some kind of cable protector that I can pop on the end of length of 20mm conduit to stop the cable chaffing? Just running cable into vertical drops in a garage.
Cheers
Spynage
As above, female bush
shopping
or by request
or
shopping
I’m sure they used to make rubber bushes for 20mm… just fitted over the cut end.
What about pvc conduit and silver paint
Galv conduit in a garage?
Bit OTT?
Bit OTT?
Those rubber bushes were for split conduit, the stuff you used to use prior to "the anyone can do this electrical lark" became the vogue, after three weeks training, when there was properly trained Electricians wiring up your new gaff.
Reply to Galv conduit question in the UK Electrical Forum area at ElectriciansForums.net
Hi all, it's been a while since I've been on, apologies. I am debating whether I need to replace the bonding to the gas meter. The meter is...
I’m running a some Adaptaflex 25mm underground and I’m just wondering where the top of the Adaptaflex meets the Pavement how could I join that on...
Hi, I have two questions about domestic wiring In Ireland 1. Should conduit be used when passing multiple T&E cables (2.5mm) through a garage...
In preparation for an EVSE installation, I am running the supply cable from the main CU, via catenary, to a new CU in my garage. The cable is 6mm...
