Discuss Help with shared neutral and wiring for disposal in the UK Electrical Forum area at ElectriciansForums.net
jtorral
Hi
My house apparently is wired in an old fashioned way with what I believe is called a shared neutral ??? Dont really know. But my breakers are special they turn two circuits off at a time and instead of a black wire only, one breaker has a black and the other a red.
So, I need to hookup a garbage disposal unit and when I remove the cover plate to put in an outlet. However, the only wire on its own ready to tie into an outlet is a black one. There are some other wires tied together and I am sure one of those is supposed to be the neutral.
The black wire on its own does indeed get controlled by the switch on the wall. However I need help identifying which one to use as a neutral for the outlet.
Please see the attached image of my drawing so you can see what I have and maybe you can answer the question. Where you see a dot connecting the two wires indicates a wire nut.
I thank you in advance for your time looking at this.
Diagram and switch wiring attached
Hi
You should have white wires under a wire nut. The white wires I’m seeing on the devices should be taped black since they are being as live wires
Reply to Help with shared neutral and wiring for disposal in the UK Electrical Forum area at ElectriciansForums.net
I have an outdoor light I am trying to hookup. There are two wires coming in with a white, black and ground. One is coming from the breaker and...
DYI guy here with some basic knowledge of electrical craft. I am helping a buddy in his remodeled bathroom. His GFCI outlet was powered off vanity...
Hello. I am new to wiring and could use some help getting this circuit wired in the kitchen . I am trying to get the source power to the GFCI and...
