Or at the very least store it wound to minimum setting.You should have it calibrated regularly already.
I'm all for the correct tightness in theory, it winds me up when colleagues use impact drivers to tighten (permanently weld) screw connections in CU's. I'd bet the correct, recommended torque, is less than normal wrist driver tightness.
If it becomes mandatory bureaucracy, how long until you need a calibration certificate for your torque screwdriver.
I haven't long bought a bosch go screwdriver, I've only used it to tighten up some kitchen doors so farThe amount of Sparks I see using their 18v impact to do a consumer unit change grinds my gears , that hammer impact action on all the connections can't be good for them. I have no idea how many NM the average Dewalt 18v Impact driver delivers but I bet its more than the desired torque needed for the average MCB or RCBO terminal.
Just looked at some of the MI and some 18v impact drivers can deliver up to 1800NM of Torque yet many Sparks think this is an acceptable tool to make CU connections
YesIs Setting your Torque screwdriver to the highest setting and using it as a normal screwdriver Bad for it ? Will months and months of it being set to the highest setting eventually mess with the Lower settings ?
Are you saying you’ve ran out of normal screwdrivers?Is Setting your Torque screwdriver to the highest setting and using it as a normal screwdriver Bad for it ? Will months and months of it being set to the highest setting eventually mess with the Lower settings ?
Not at all , I love a Screwdriver and still have my old CK set and old WIha set in my every day carry bagAre you saying you’ve ran out of normal screwdrivers?
Using it as a screwdriver without going over the torque setting shouldn’t do much harm, but hitting the setting and continuing to tighten, I wouldn’t have thought would do it any good.Are you saying you’ve ran out of normal screwdrivers?
It’s ok if you can afford to waste themNot at all , I love a Screwdriver and still have my old CK set and old WIha set in my every day carry bag
But I have 2 Vde torque sets that see the light of day maybe once a month and I have considered just ramping up to the highest torque and just using them as normal everyday drivers
I do this ALOT and I know it makes using a torque driver a bit pointless but its just the way I'm wiredUsing it as a screwdriver without going over the torque setting shouldn’t do much harm, but hitting the setting and continuing to tighten, I wouldn’t have thought would do it any good.
I must admit I alway go over terminations again manually with a normal driver at the same time as giving the cable a wriggle near where it terminates doing it that way I sleep better![]()
Why not just go over a 2nd time with the torque driver?I do this ALOT and I know it makes using a torque driver a bit pointless but its just the way I'm wired
Here where I am the local regs limit the number of wires in any terminal or termination to two unless it was specifically designed to accept more. Do the UK regs allow multiple wires in a single termination point?Wheel nuts and electrical terminals are different situations.
The torque value for the wheel nuts is set knowing exactly what is being fitted, what its made of etc etc.
Electrical terminals could have a range of types and sizes of conductor put in them, there may even be multiple conductors in there. I can't see how one universal torque setting can be correct for all sizes and types of conductor.
blimey![]()
I have had both my vde torque drivers for well over 4-5 years and neither have been re-calibrated yet
Good job I check with my manual screwdriver after torquingJust think of all those terminations that might be done up to precisely the wrong torque!![]()
Single conductor from mcb to a multi join. ?“So, new circuit… you can’t use maybe an existing spare mcb?”
