Aug 28, 2022
London
Trainee Electrician
Hi all,
Can anyone recommend a decent 24V DC constant voltage LED driver.
It’s for an install of bathroom niche LEDs IP65 downlights. They are mini and have a 35mm cut out. The 1.5mm T&E is already dropped to each cut out but need a driver that will fit through a 35mm whole and to be pushed up.
Many thanks,
Jay
Hi all,
Many thanks,
Jay
google tridonic led drivers, go to the tridonic website , find the right one for the power required and check the dimensions, get product code and order through your favourite supplier
Thanks. Had checked them already and can’t see one small enough to fit through a 35mm hole.
That's over 34mm 'across corners' so will have to go in almost vertically. Do you have 305mm head clearance?
Reactions: Jay92191
Yeah head clearance all the way to the ceiling as there are no across noggins, so it will have to go vertically. Just a shame there are no smaller drivers that fit through a 35mm hole.
Reactions: brianmoooore
The cut out is 35mm but what about the width of the downlight with the bezel? You can gain maybe a few more mm so you could possibly cut a 40mm hole instead, just saying...
Reactions: Jay92191
London
Trainee Electrician
24v DC driver for LED lights.
Lighting Forum
Jay92191,
Ursanelec,
