Discuss Urgent: 60 amp main cut out fuse required in the UK Electrical Forum area at ElectriciansForums.net
youre welcome glenn :-D
I am with inner knowledge but I yearn to reach higher levels before I go forth into the world.
I will carry water up 100s of steps and be abused day and night to learn the deeper secrets.
all this mumbo jumbo about the "force". join me on the dark side and see the power of the force. i came from the planet zog, several millennia ago and was transformed into a humanoid circa 1946. since then i have created earthquakes, tsunamis, forest fires, volcanic eruptions, even tragedies like neighbours, emmerdale and eastenders, culminating in the final creation of the arch crimimal tony blair, but still the human race will not listen. in order to save the human race from extinction, i have no alternative but to call on the powers of the klingon empire to save them.
Best thread swerve EVER!!!
Back to the original point he could have found that fault without power anyway with a simple multimeter although I feel right now nobody cares!!!
So off from WW2 films I rather like the great escape myself.
I've known of an 80A main fuse blown on one phase whilst energising a 3kw heater on it's own radial with no faults and downstream fuses ie 30a and DB main fuse untripped. Everything tested as ok, terminations checked at f/s and in heater all ok. Replaced 80A fuse and no problems since.
Maybe over time they can lose their characterisitics? I'm not sure?? It was very strange.
like owt in`t it.....
dont think fuses dont get tired safety......
Reply to Urgent: 60 amp main cut out fuse required in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone, On a job at the moment and trying to Work out cable size needed for property supply. Lots going on and struggle to work out...
New member and DIY. I have a 60 AMP breaker going to a sub panel for a workshop. Two months ago I bought an electric car and a 40 AMP charger...
Can someone sanity check my thinking please.... An 80 amp PME service head, tails to meter, 25 sq mm tails into an enclosed fused isolator with...
G99 GSI-3 4.4 kw Victron inverter install with EES and batteries and installer can set the export lint if required by dno As part G99 GSI-3 you...
I'm having an extension built and the builder leading the project has said that the electrician will be over in about 4-6 weeks to start his works...
