Discuss Substation right across the road - PSC in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
S
se7aq
Hello
Testing for PSCC and PEFC with the substation in view from underneath the staircase, I got one reading testing PSCC on 2000A but overload on PEFC. But on 20ka I got tests results on both PEFC and PSCC. Can I use these results on my certificate for PFC?
Cheers, as ever.
Was using a new megger 1730 with my last employer, that used to throw up 20ka PEFC, when tested again with a different tester it would always come back with a more predictable reading.
Sent the megger back and it had a firmware update or something, and it eorked fine after that.
So, what tester were you using to record the high PEFC ?
The last reply was correct by saying the service cutout can handle the 33Ka.
Reply to Substation right across the road - PSC in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Over the last few days, I have stumbled across a number of threads that seem to point to a prevalent misunderstanding. Either that, or I have been...
Hello all, Looking for help here as I've come across a strange call-out today. Bare with me here: Got a call from a customer saying they had...
Hope this all makes as much sense as i can make of it and my "problem" can get sorted via some guru on here... Just a quick background on myself...
am i correct in thinking for determining the PFC, you can do a PEFC test aand PSCC test and which ever one is highest you can double and choose to...
5K
Hello ! I am building for some time a cct to drive a 3digit multiplexed LCD. (from aliexpress) From the sellers on aliexpress I managed to find...
