Discuss LD2 or LD3 fire alarm system in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
I'm about to install a fire alarm system in a two storey house which will be let as a single dwelling. In Electricians guide to fire detection and alarm systems it has table 5.4 specifiying which grade to use. The old tenant has moved out and the landlord has decided to spruce it up, new bathroom, new kitchen, knock a few walls and some electrical work. Does that make it a 'Materially altered dwelling'. If so it would mean adding another optical in the living or dining room and a heat detector in the kitchen. What would you guys put in? Cheers
If building control are involved, then they will state the Catergory. If the house is being rented out privately or through council, agency, Grade D cat LD2 covering circulation areas and kitchen is usually accepted. Good link by Glenn, Aico showing all grades now to stop a lot of confusion.
Reply to LD2 or LD3 fire alarm system in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi all, i'm just after a definitive answer regarding a fire alarm system in a communal area/stairwell. There are call points, smoke heads &...
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
Hi, I'm completely rewiring a 9 bed 3 storey HMO in Jan, The fire detection required is just some linked lithium detectors in the...
I know this has been brought up before but as a QS for a housing association ,i have been asked my opinion on interpretation of the regulations...
I am doing renovation to a cafe in Scotland at the moment and after speaking to the local council the building requires the minimum standard for a...
