Discuss DOL starter 7.5HP, 3 ph motor in the Commercial Electrical Advice area at ElectriciansForums.net
230v control is what was present on the machine already. is 230v control a problem, or just not ideal? And if so, Tony how would i generate a 24v DC supply voltage from a three phase incoming supply? Would i need a DIN mountable transformer or something to generate my 24v control for the switches or is there something else. Been looking through RS but frankly not sure what im looking for.
But i still need a 24V supply..... im going a little mad....and talking to myself at my desk....why is there a penguin under my desk? Who stole my electric wok......why can't i breath properly.
How?
The starter has to be reset.
If this is in response to post#50 {wrt post #34} then the wire from 13 and linked from L3 (if I'm reading Wade's schem. correctly) goes to the unswitched side of the start contact, through the stop and pressure switch to A2 thus powering the coil if the pressure switch is/becomes closed!
I'm humble enough to be corrected though.
The schematic shows the control wired across 2 phases mate hence 415v not 230v :)
edit.
That's an old drawing and not relevant here I gather..........soz :)
You know they give us all a laugh, so why not...
Hows the Risk Assessment coming along?
Dont take this the wrong way mate, but I hope you do the design fully before you purchase any components.
The risk assessment currently says:
Ribbon Blender Operation
Who is at risk: Ben
What are the hazards: Ben
Evaluate the risks: Ben might die
Recorded findings: Ben is dead
Risk assessment review: It's a shame Ben is dead
Alright Spoon, you've made your bed mate.....
haha Am I coming across like an annoying s#*t??? Im good at that..... Dont really mean to....
Wade over time it’s been obvious you can’t/won’t grasp the safety aspect of plant control.
Just remember if someone gets hurt it’s you’re neck on the block. The HSE are very good at swinging the axe.
They tried to get me, I was facing criminal and civil charges. I was totally exonerated but I went through hell in the process.
Just look at a TV near you " Have you been injured........................"
No Tony youre right I wont grasp it by just expecting to learn all i can from this forum. I need to seek professional tuition and spend some time with someone watching how they worl and getting stuck into some solid theory... I don't expect to be competent in such matters after a couple of hours spent sat here talking to you lot.
But
I enjoy coming here, to ask the questions i am unsure of and to generate discussion around these points to facilitate my understanding, albeit maybe slowly and not very efficiently, however i feel it is useful nonetheless.
Control is not something i do much of, but have the potential to do lots of, i also, contrary to your opinion have the potential and capacity to learn given the right circumstances, what i need to in order to be more than capable to overcome the tasks presented to me here.
Not taking my bat home at all and I fully understanding the implications of making a cock up and someone getting hurt, but i feel it is better to ask the questions, rather than blundering on ahead with it.
I can/will grasp the safety aspect on plant control, after all, if you managed it, im perfectly sure i can. I have discussed with my seniors here sending me away on a control and automation course to aid the beginning of my learning curve, hopefully then, i wont have to waste your time replying to my threads mate. I have had zero face to face help with plant control, i have managed to learn what i can from advice given on this forum, and will continue to do so. It is, after all, what it is for.
Much as I’d like an apprentice again I’m now too ill to work. BUT I will help you where I can.
I had to accept change from the simple control of 40 years back to take on board the changes in legislation. You are now constrained by that legislation from the outset.
Modifying a basic starter becomes embroiled in red tape. The stupid thing is, nothing in the basics has changed, its just more complicated.
I spent time in R&D with a totally lunatic production engineer. I had a notice above my desk, “I’m looking for ways to stop it!” He wanted everything speeding up.
Stopping a plant safely is the prime directive.
Some plant designs I’ve done where massive centrifuges were used, part of the program would short out all the safety interlocks. Overloads, thermisters, et al all bridged out by the program. It didn’t matter if the motor was on fire, it had to keep running! If someone was wrapped up in it, their dead long before anything can be done about it.*
For it to start its cycle everything had to be in place.
It would be too dangerous to stop the machine without it going in to a controlled emergency shutdown mode. Shut down took time but it stopped as quick as I could get it to do so safely without endangering the other workers.
The original design had an E-Stop, it just cut the power and it drifted to a stop. My set up the centrifuge went in to regenerative braking but only if the temperature in the centrifuge made it safe to do so. The first thing that would happen is three X 150HP water pumps would kick in to cool the centrifuge shell. The temperature in the centrifuge could be 1300°C
*HV work, one question you get asked is “what do you do if someone receives a HV shock?”
The answer is callous, “assume they are dead!”
The safety of the living is more important!
Have sent you a PM.
Have sent you a PM.
FFS, no wonder you are ill , thought we had it rough.
Reply to DOL starter 7.5HP, 3 ph motor in the Commercial Electrical Advice area at ElectriciansForums.net
Hi there, I got a call to a job, table saw (wood) tripping C/B straight away. 4kW motor on Star Delta Starter. So I get to the job, after some...
Hi all. I'm looking to build myself a rig with a small single phase motor and learn a bit more about motor controls etc. I mostly do domestic and...
4K
Hi, I kinda think I know the answer to this but will ask opinion anyway. I am fitting a new compressor pump and motor to my receiver and have...
8K
Advise Please. Called out to my local farm, who deal in fruit and veg, to a DOL starter switch which cuts out after a minute or so. This switch...
8K
Could I use a DOL Starter circuit to create an automatic extraction system? I was thinking that I could replace the start button and simply wire...
