Discuss unusual ceiling rose wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
S
sijaysee
Hi
i was just painting my ceiling and unscrewed the ceiling rose to cut in and noticed that the wiring doesn't look quite right.
there are 3 cables so i assumed 1 in, 1 out and the switch. There are 3 reds in the centre block, 1 black in the 2 gang block with the neutral of the light, and 2 blacks in the other 2 gang block with the live of the light.
Any ideas?
many thanks Si
If you're concerned about it and know enough to do it safely then drop the flex out and swap it over. Leave the ceiling rose connections alone, the flex is the easiest way to do it.
the N block should have 3 terminals, not 2.
and , of course, the black switched L should have a red sleeve fitted, or is it brown. what's the colour of the day, lads?
Dyna beth yw pentwr cyflawn o ceilliau tarw. Dim ond profi'r meddalwedd cyfieithu ...
neu well
Confusious可能会说,经过一个晚上,在弹出:比成鸡挤自己最好的东西山羊
Reply to unusual ceiling rose wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hello everyone, hope all are well. I'm changing a ceiling rose and have lost the diagram showing where everything was connected (to the old light)...
Hi, have an old bathroom fan. Which has two wires the black and red (line and neutral). The fan has no isolator switch and was powered when the...
Hi all was having a problem with lights work one min not next took ceiling rose cover off to find a stray black wire only terminal free is the...
Hi guys, I have recently encountered that my circuit breaker for the upstairs lights keeps tripping. I flick it back on and immediately it trips...
