Discuss 110 extension leads in the UK Electrical Forum area at ElectriciansForums.net
you'd probably get away with 2.5mm in free air.
Thanks telectrix, been doing some pat testing off shore on wind turbines and from what I can see the maximum 2.5 cable can take is 27 amps. Am I missing something here.
hint. ref; method E. alternatively, get manufacturers data on the cable. yo'ull find that flex, being multi fine strand will probably withstand a higher loading than the figures given in BS7671.
a problem you may find is that the only fusing is on the primary ( 240V ) side of the transformer. to cope with inrush, this will probably be a 32A C type MCB.and that's for 1 transformer. if you have several transformers running on 1 circuit, then the OCPD rating will do nothing to protect the 110V cables.
that's because all the power is being used to turn them offshore fans.
I personally think it would be the other way round the house would be powering the wind turbines , im sure its a only matter of time before a ship hits one of the hideous things off the north wales coast
Reply to 110 extension leads in the UK Electrical Forum area at ElectriciansForums.net
Hi guys, We’ve had a new CNC Machine from China arrive this week. It came with a monitor and a tower to run the software. The monitor and tower...
Hi, just hoping for a bit of advice. When I travel abroad (Europe, predominantly Spain/Cyprus) I usually take a single travel adaptor and a UK 4...
Hi Guys. Is it safe to use an extension lead with a single pin 48V battery charger for an e-trike? The charger has a standard UK 3-pin mains plug...
DIYer question. I have a 32 amp supply going from consumer unit in garage to kitchen. It supplies an induction hob only. The cable is easily...
Hi ..right where do i start ..ill do the best i can !! i have an extension lead and in it are plugged a fridge , a separate small freezer ...
