Discuss 12v AC/DC adapter re wire question in the UK Electrical Forum area at ElectriciansForums.net
Hi there all, I have a question.
I've just purchased this repeater:
Technique Specifications:
Item Specification
Up Link Donw Link
Frequency Range 890MHz ~ 915MHz
1710MHz ~ 1785MHz
935MHz ~ 960MHz
1805MHz ~ 1880MHz
Power -70 ~ -40dBm/FA (1.23MHz)
Gain 60±3 Db 65±3 Db
Max Output Power +23dBm / ±3dBmTotal Power +23dBm / ±3dBmTotal Power
Impedance 50Ω
Power Supply AC 110/240V (used AC/DC Adapter 12V dc)
Seclusion >70dB
Compact Design Indoor Use
Item Diemension 240 x 180 x 20mm
Connect Mode N connector
Ambient temperature -10°C~60°C
LCD display function
can display signal strongness which it receives from outdoor antenna ,
the signal bar will be full black if the signal is received very good.
The unit itself says 12v DC, but the actual power supply looks like it inverts AC>DC. I was trying to work out if there was a way I could hard wire this straight to my 12v battery bank in my motorhome?
The idea I had was to go straight from the battery terminals with an inline fuse, snip the end of the supplied adapter and rewire this to connected battery line.
Am I on the right track here? I am a complete electrical novice so please excuse my ignorance.
Much appreciated!
Hi sorry for the double post!
The unit would only be used in European countries where there are no restrictions in place.
What in line fuse and gauge of wiring would you suggest to be safe running this unit directly from the 12v leisure battery?
Also from the specs above what sort of ah draw would you expect from this?
Again thanks for the responsiveness!
Should be fine. Although the psu inrush current may be high enough to pop a 3A fuse. May have to increase it slightly.
How long will the cable run be?
Should be fine. Volt drop shouldn't be an issue either.
Brill. Final newbie question...
This particular unit doesn't have an on/off switch. When pulling the power connector out of the unit will this still draw a residual current off the 12v battery? If so, would it be worth popping a rocker switch into the circuit to avoid so (obviously looking to conserve as much of my leisure 12v power as possible)
Thanks!
There's no residual current if you have unplugged it. Unless I've misunderstood something.
No worries. If I ever have an antenna impedance matching problem I know where to ask!
Reply to 12v AC/DC adapter re wire question in the UK Electrical Forum area at ElectriciansForums.net
I used 12v dc from a 13 plate car battery to power a 12v dianamo dc motor and brought in an alternator to change the battery using the rotation of...
I decided to get solar panels, the inverter instructions say one can use type AC, so the existing 14 x RCBO CU seems OK, may be a good idea to fit...
Hi, I understand some basics about wattage, volts and amps etc but I am trying to decide what would be the most efficient system Situation - 2 x...
Hello, I am fitting a Telecom 8 Compact burglar alarm system to a boat. The boat has both nominal 12v DC supply (ie up to 14.2 v when engine...
I'd like to find a timer switch, in a style that looks alright next to decora light switches, to control a bathroom fan. The bathroom fan...
