Discuss 12v between live and earth and 12v between live and neutral in the UK Electrical Forum area at ElectriciansForums.net
New to this so be kind.
Run a new circuit in today gone to do R1+R2 on the circuit me at the end of line and the other spark putting the link in at DB. Tester starts bleeping voltage so at first I thought he’d turned the circuit on but he hadn’t. On further investigation I’ve found that from the live of my new circuit(breaker switched off) to earth bar at DB getting 12v and from same live to neutral bar I’m getting 12-13v. It’s only when I start knocking off the lighting circuits in this DB it drops.
I’m worried because never came across this before.
That’s getting to become your answer for everything Jester!
I do hope you got more than that!
Now where did I put that smiley face emoji!
It's probably capacitive coupling from other cables, although with the L linked to E I'm surprised it happening.
what type of cable is it and how is it installed, is this singles in trunking?
Check all connections, terminations and continuity.[/
t+e cable.cable tied together above a ceiling grid. The cables enter board through stuffing glands some individual some with other circuits. There are 3 x lighting circuits(led panels),dado socket circuits x 4 , boiler x1 and the RSD circuit
Well that sounds like a delightful installation.
If they are all cable ties together then I'd say it's capacitive coupling.
Hi,what device were you using,to record this voltage?
It is about,the most important part of the question.
We don't know,if you used that apparition detection meter,off Ghostbusters...;)
Reply to 12v between live and earth and 12v between live and neutral in the UK Electrical Forum area at ElectriciansForums.net
Hi was recently at a property and was installing a Solar PV system. was doing my testing and i came across a weird result when doing the...
Hey there, Sorry I’ve just joined up. I’m a qualified electrician/Electrical engineer. Recently sat my 2391-52. My question is I had a fault...
Just interested in peoples thinking on using the neutral through the earthing system like I came across today. I've come across many wrong...
Hey, I lifted a few sockets from a wall so I could paint without having to cut in around them. I haven’t lifted any light switches yet. When...
