Hello, I am currently DIY upgrading a caravan with my girlfriend but need some advice.
The (very old) 230VAC to 13.8VDC power supply broke down and needs to be replaced. It is rated with 10A output but I would like to replace it with a 12V one with at least 15A. The old supply was intended to also charge a lead battery but we do not have one nor do we want one.
So searching for a replacement I noticed the special caravan power supplies being much more expensive than other 12V power supplies. E.g. the MeanWell XLG-200-12-A is intended for use with LEDs but I don't know the reason behind that. It has different kinds of protections included and provides enough power. I would love to buy that.
(I want to stay away from those cheap noname 20€ power supplies)
FYI: There is lighting, a refrigerator, a water pump and USB power ports to be driven by that 12V.
There are already two relays next to the other electrics in the caravan (for priority power) so I do not need those integrated priority relays.
So in the end I want to know if the MeanWell power supply would be fine or if there are reasons to take a specialized power supply. If you can make suggestions please do so
Thank you in advance!
