Discuss 17th edition and UFH in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Dave
Hi all.....
Has there been any changes to the installation of electric under tile heating in bathrooms etc.....
I am a tile fixer by trade . How has this effected if any the installation for tile fixers if we use a sparky for the connection...which i know you have to anyway..:)
What i want to know is... has this changed in any way....:confused: now the 17th edition is out..??
Hi all.....
well in the 17th, floor and ceiling heating systems is now a special installation/location, in Section 753
I cant vouch for what has 'changed', but there are three pages in there for it, but the big thing to consider is that UFH in bathrooms would mean you would have to consider Section 753 AND Section 701 (Bathrooms), and 701 has changed considerably!! (RCD's, Zones, Supp bonding etc)
be worth you digging it out and having a look;)
If you don't understand what Shakey is saying then you should not be dabbling with the electrical side of the installation. May I suggest, for your own professional standing and the safety of your good clients, you get a registered electrical contractor to take charge of electrical side of your work. You will then be able to sleep soundly! Hope this helps!
Reply to 17th edition and UFH in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I have a loose wire underfloor heating system I am installing for a client ideally they would like the UFH to continue into the down stairs loo...
Hello all Planning to do the 18th edition online. I could just batter loads of old papers on the head and then have an attempt ( I will do loads...
I am currently going self employed. I was never put through any 18th edition courses, so have booked myself onto my 18th wiring regs. I want...
Hello all Well, been putting it off, but I need to upgrade my 17th edition to the 18th. Not been a practising sparky for over 5 years, but I have...
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
