Discuss 2-way switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
In a domestic installation all cores should be identified as either line, neutral or earth ( brown, blue or green and yellow ) sleeve them up baby.
You wouldn't want the owner getting a shock when he changes his switches to chrome would you, where does this grey one go and what does it do??????????????????????????????
Keep cutting the seals!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!:):)
if its the only way go for it !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!:):):):)
Reply to 2-way switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I’d appreciate your professional views on this question, as I’ve had 2 of the associated electrical bodies quizzed on this.!!!! ON changing/up...
I have a baffling problem with a newly-installed PIR floodlight and I'd like advice from the forum as to whether it's defective (and should be...
Hi all. Yesterday I wired in my 3 phase compressor to run off our 53kva generator. I just need to know which colour cable is for which phase as...
