Search the forum,
Discuss What cert is best for a new spd install? in the UK Electrical Forum area at ElectriciansForums.net
Brand new spd installed new tails, saying minor works is ok, I don’t believe so as tails are coming from metering supply via Henley blocksNeeds part p certification and an EIC cert for new CU/Relevant supply variation to current CU - new tails=new circuit, new circuit=new board(spd unit), New 'board' = part p and EIC.
It is tantamount to a new Consumer Unit of sorts (SPD device) and new tails and so I would reccomend an EIC and Part P notification - it is a new circuit (main fuse to SPD is a new circuit) so this is NOT suitable for a Minor Works.
Reply to What cert is best for a new spd install? in the UK Electrical Forum area at ElectriciansForums.net
Client needs an SPD fitting but no room in c/u or adjacent. Best bet looks like a parallel connection into the tail blocks in the meter cabinet...
Hi guys, could someone help with the following please? The scenario is: Domestic property supplied via three phase (with a 3P main DB, NO SPD)...
Hi fellow sparks, I've just started out on my own so I'm spending a lot of my time trying to find out the correct way of doing things of...
Does a SPD need a dedicated way? I need an extra way in this unit for a 3 phase car charger As you can see its a small unit with no extra...
Hi, need your advise please as need to take supply for Electric car charger from the meter cupboard. This meter cupboard has an isolator and...
