Dommer66
Ok I’m not electrician, just trying to save money. And just wanna get some input before I continue.
I added a 20a breaker to my circuit box, ran 10/3 to a 220 outlet.
Hots to my X and Y, neutral and ground all went to this outlet. 2 hots to the 20a, and my neutral and ground to the spot in the box for them. I had to join two rolls of wire together with wire nuts in the attic.
I was just about done, cleaning up. And after I tested the outlet with my meter. Went to push it back into the box, and POOF. Bright flash and a pop and it was smoking. Like I said it tested fine on the meter and I didn’t have a problem till I tried to push it into the outlet box. I had all my wires screwed down tight as I could, I triple checked. If anyone has any idea what I could’ve done wrong please let me know.
If it makes a difference this is to power a tanning bed for my mother in law. But I didn’t even get to plug it in like I said. -TIA-
You pushed it back into the box whilst it was still live?
Reactions: Megawatt
I'm not an electrician so this is purely a question for my sake - what did you test? I'm guessing the faceplate of a socket? And then tried to screw that faceplate back into the back box (note: I'm UK-based, language might be a bit different)?
I know this is old but as stated above you pushed it in live and somehow the bare ground touched the live screw
220v help PLEASE
DIY Electrical Advice
Thread Tags
Dommer66,
Megawatt,
