Discuss 230 supply to 110 outlet sockets in the Australia area at ElectriciansForums.net
schoe
I was just wondering out of interest how from a 230 supply you can have 110 outlets sockets. I was in a work shop today and saw these 110 sockets that you can just plug your equipment into and I was wondering how you would wire them.
Would you need to wire your 230 supply into a step down transformer then wire your 110 sockets from that,
Cheers
Chris
Yes pretty much so... their will be a quite hefty transformer mounted somewhere and out of this you get your 110v supply.
This is a very generalised reply without going into the layout, fusing etc etc
I did one ages ago on drop downs , Three phase , 110, 240, airline and air extraction unit all on one drop , Can't remember the name of the system though.
If we were in America it would be no problem. 220V = 110-0–110V. But in good old Blighty we’re stuck with using transformers.
The American system would be end tapped, not acceptable for power tools in the UK.
Essentially you will have a 230V supply (depending on size) into a wall mounted Tx. Out on the secondary side you will have a supply to another DB containing double pole MCB's protecting the 110V wall mounted sockets.
Reply to 230 supply to 110 outlet sockets in the Australia area at ElectriciansForums.net
Hi all, Just a quick one regarding the need for RCD protection for socket outlets rated up to and including 32A. I have been tasked to install...
Bought an air compressor at auction. Looks to have been previously hooked up in the previous owners shop. It has two wire Romex coming from the...
Hi, This post is about my concerns with medical IT socket outlets and want to alert you all if you are fitting them in a hospital. The current...
This is probably an easy question for an electrician but I was just curious about the theory. (I'm trying to figure out how things work!) I read...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
