Discuss 3 phase of 2 phase supply in the UK Electrical Forum area at ElectriciansForums.net
Split phase supply L1+L2 on one phase and L3 on another, EB has 3 phase 4 wire incoming but they’ve been out to check and said it’s split phase, what would you put on certificate? 3 phase 4 wire or 2 phase 3 wire?
Reply to 3 phase of 2 phase supply in the UK Electrical Forum area at ElectriciansForums.net
Hi I have UPS 50KVA and the inverter output AC voltage is feeding a distribution panel 120/208 V 4 wires when I check UPS display it shows me...
Anyone come across this before? I was asked to do a Zs on a 3ph surge device; L1 was around 6 ohm, L2 & L3 around 0.11. Wired in singles from a...
Good morning, So I’m working on an existing 3 phase solar system and the customer wants a way to use the huge mass of exported solar on their...
I have a scenario where there is a three phase DB in a commercial property where there are mixture of three phase and single phase washing...
