Discuss 3 position switch ; ON-OFF-ON in the UK Electrical Forum area at ElectriciansForums.net
Hello
I'm after a switching solution to my shed exterior lighting.
The shed is located 20metres from my house and is currently switched locally by a standard weatherproof on/off switch.
I'd like to have remote switching to illuminate my path down to shed.
I've looked at PIR switching but the range seems to be limited to about 12 metres.
I've looked at wireless switching but that's very expensive.
I like the idea of photocell switching but i'd like the option of an override facility to manually switch on the light before twilight or after dusk or to switch the lights off completely i.e when i'm away from home.
I was thinking of a switch that can switch the line conductor ON-OFF-ON and to be weatherproof.
Cheers
Hello
Cheers
Why do you need that arrangement?
I'd like some illumination to light my way, rather than carrying a torch. Shed is beyond the reach of a PIR light.
this will do for the job!
Hi dude,i suppose you are going to be asked,if you are simply changing a fitting,or altering the switching arrangements of a circuit...
Reply to 3 position switch ; ON-OFF-ON in the UK Electrical Forum area at ElectriciansForums.net
I'd like to wire a six pin DPDT rocker toggle switch to turn a low voltage LED fixture on and off. The rocker toggle switch I have is an...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
Hi all, I'm planning on adding some lighting to an old stone shed, there's currently a 2.5mm² SWA supply to the shed only supplying one IP rated...
Bit of a rant first to explain the situation:- Effing builders again, I knew there was a reason we hardly ever work for them. We've done a few...
