Discuss 4" extractor fans 5meters & 7meters in the UK Electrical Forum area at ElectriciansForums.net
TJC1
Does anybody know of a 4" extractor fan than can do up to 5meter with one 90 degree bend in it?
Also a fan that will do 7meters with two 90 degree bends in it?
Looking at a new build in a old barn which they are using the old tin roof as the roof of the property. There is no access in the loft and they fans cant be inline....
You can get recessed centrifugal fans which would take the bulkiness away. Good fixing to keep the vibration down. We used to use Vortice Quatro in Barratt houses.
Okay Anthony, I'll bite!
On checking the specs on their website, mine beats their 'quadro micro 100'. However the "quadro super' annihilates it at 77 l/s or 280 m3/h!
Thanks, saved for future reference
It's nothing to do with biting the only reason I disagreed with your choice of an axial fan in post 5 was the company that I used to work for fitted axial fans against ducting instead as the spec said centrifugal and I must have had to replace 30+ in peoples homes that were under the first year that they had moved in.
Reply to 4" extractor fans 5meters & 7meters in the UK Electrical Forum area at ElectriciansForums.net
Hi, my niece lives in a flat and has a bathroom without a window. There is an extractor fan which packed up and an electrician installed a new one...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
Hi I have bought a new bathroom fan to replace a faulty one. I don't have much cable available (emerging from wall) and it won't stretch to the...
My extractor fan has given up the ghost this week and I was hoping to replace it myself, however I cannot do a like for like swap as the current...
