Discuss 75 metre supply in the Canada area at ElectriciansForums.net
M
Mark
I need a 13amp supply for a hydralic motor for a horse walker 75 metres away from the consumer Unit
What size cable as the distance is quite high?
Is the horse walker inside a building ?
If so over that distance I'd think about a 10mm swa submain supplying a consumer unit wired as a TT system, then have a circuit installed for the supply to the walker.
No, The horse walker isnt in a building but the motor and all other electrical components will be in a small hut.
Reply to 75 metre supply in the Canada area at ElectriciansForums.net
Hi everyone, I intend to bury a 240 volt cable from my house to my barn about 7 metres as way. It will be buried under my tarmaced drive which I...
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
Hi all, I am at odds on whether RCD protection is required on an SWA of 14 metres, clipped direct under flooring direct from CU to an exterior...
Hi folks, I have recently had a 5kW Solis inverter and 15kW/hr of batteries installed. Everything is working fine, but I have some concerns about...
I would like to hide the cable to an EV charger. The consumer unit, meter cabinet and charger would all be on the same wall. About 5 metres from...
