Search the forum,
Discuss A few questions on writing out an EIC........ in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
What would you put down for the main earthing conductor? As it's PME it's hidden inside somewhere with nothing on show. The meter room feeds several Ottermills, which then feed down to the boards I've worked on - at which point do I measure the CSA of the earth? Would I be best to put down 16mm as that's the earth to the board I've worked on for this certificate? I'm really stuck with which figures need to be noted and I would have thought the first bit of earth on show is once you get inside a submain, everything before that is nasty busbar stuff in the Ottermills.
Same for the bonding, it's all hidden away, the gas meter is in an outside building and feeds the school from underground. I guess the bonding will join the gas main as close as possible to where it comes into the building, and not outside where the meter is. This splits to about 12 boiler rooms around the site.
Thanks for everyone's help so far but I'm really struggling with the scale of this place, the work is no different from normal but when the main supply and distribution is so huge how do you go about filling in these bits on the cert?
Hi I am an apprentice and would like to know if when wiring lighting via a key sw does my feed and my emergency brown go togeather with my sw going out of the bottom side of the key goin to all non emergency lights
Reply to A few questions on writing out an EIC........ in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi - just after thoughts on this please. I've been doing some testing on a 20 year old MCC. On the original EIC, Ze was reported as 0.04 R, PFC...
Hi all, Probs a simple one here but when testing a 3 phase board for ze as part of a periodic inspection plus part initial verification of a...
I have been asked to provide a quote for a supply to an toilet block on a campsite. The three phase supply to the campsite is approx. 150m from...
I'm interested how you would all approach this one. A 3 phase distribution board on a caravan site, under lock and key. Only warden and manager...
I'm practising EICRs on friendly locations as I'm still in training - technically done my 2391-52 but frankly need loads more practise. I've just...
