Search the forum,
Discuss Adding a socket from a Fused spur in the The Welcome Forum area at ElectriciansForums.net
It's in a kitchen so fridge freezer, kettle, toaster that kinda stuff and washer and chimney hood plugged into socket I would be installing fed from a rcd fused spur with a 13amp fuse would that then be acceptable and most importantly safe?
So it's not supplying just a washer now?
Pmetcalfe, in post #11 you stated that you would investigate whether the circuit was RCD covered and now you plan on RCD Fcu feeding the socket. You need to be careful on here that you tell it as it is. When there's blood in the water they can smell it!
If this is your dwelling, tell it as it is, be honest and the forum is willing to help. Read the books, take a look at appendix 15 in the BS7671 and acquaint yourself with fault protection requirements and additional protection. You'll need to do a lot of archive reading from the forum - use the search button and get immersed, that's were you will get your answers. All respect intended. Rob
I am just looking for possible ways to do this as I haven't looked in the CU yet I don't k ow if there is a rcd in place I will be reading through my onsite guide and relevant books before doing the job thanks for your concern and messages
If the 20A radial circuit is in fact supplying the rest of the kitchen, it may already be overloaded as there are several items mentioned which draw a large current. Adding a washing machine to the mix my well cause overloading of the circuit and nusense tripping.
Ideally the circuit needs upgrading to a 32a ring or a separate radial for the washing machine/cooker hood.
Reply to Adding a socket from a Fused spur in the The Welcome Forum area at ElectriciansForums.net
Wiring cooker hood into a switched fuse spur with a 13amp fuse in the spur. The cooker hood is 3amp. Should I swap out the 13amp fuse in the spur...
Hi I have a switched fuse spur where the cooker hood should plug in to… above the actual cooker. I was wondering if I could swap this out for a...
DIY'er question: I have a singe switched fused spur above my kitchen counter, providing power to an undercounter fridge socket beneath it. The...
Grateful if someone could offer some advise, I'm struggling to find a definitive answer to this. I have a double socket, it was on the ring main...
Hi guys, newbie posting! Does the following sound ok... Existing circuit: SOCKET on a ring -> spur to SWITCHED 3A FCU -> SWITCH -> hardwired FAN...
